if manual repels or attracts buyers.
Repels some, attracts others.
I once called a guy in NH who was selling a manual V/XC-70.
He repeatedly mentioned that it was manual and told me the message still doesn't get through to many.
He said they'll show up and say they can't drive manual.
If a different look for the shifter is desired, "the Spaceball" shifter is available for that family of vehicles.
Stories of them popped up often so it's apparently a veery doable mod.
You have the 2.3 liter 5-cyl. upped to "T5 status", which I think is ~240hp?
Ha-ha, as always, job #1 with that car is physically examine both rear parking brake mechanisms.
You're checking for delaminated shoes with bits of friction material free to fling about. Replace with Volvo only.
Also give the headlamp sockets a look as Volvo used inexcusably thin plastic which crumbles away.
I've replaced a few. NAPA #787143 for the H11 bulb.
Perhaps you have the Zenon option?
Also, soldered joints are said to cause the common instrument cluster -DIM- failures.
The blue "high beam" indicator would fail to light in my 2002. The failure didn't deepen.
However, the one in the 2007 went completely nuts; every LED, gauge and the entire message screen flashed frantically.
The company I found is actually having a special, $300 offer on these particular 2001-2008 DIM repair. 1 year warranty.
Because I just used them, reinstalling my repaired DIM -same as yours sans any boost meter- yesterday, I proffer the name of the electronics repair shop.
The entire turn-around was 2 weeks.
Up Fix
4991 B U Bowman Dr.,
Ste. 100,
Buford, GA 30518
ph. (888) 979-9343
Best of luck with that cool car.
It's not necessarily an AWD, yes?
