Have any of you seen this before? It's the Kublin Method over on the Paradise Garage site (Theory #5):
Paradise Garage--Oil Change Theories
At first glance, I liked this method a lot because:
a) It’s simple—just find out the virgin TBN of the oil you are using and plug it into the formula. The other info you either know or can find out in your owner’s manual.
b) It takes into account the amount of horsepower relative to engine size—a great way to factor in the stress your engine is under.
c) It indirectly accounts for driving style by including your mpg. (More highway miles is much easier on the engine, so your drain intervals will be longer.)
But started to have some doubts when I saw Kublin works for Amsoil and only gives Mobil a value of 8 when it’s actual TBN is 11 or so.
Do you guys think this a valid way to figure oil changes, or has Kublin simply devised a clever way to promote the superiority of his product line?
[ July 16, 2003, 02:04 PM: Message edited by: Rexman ]
![[Wink]](images/icons/wink.gif)
