Originally Posted By: LeakySeals
Originally Posted By: ltslimjim
Well, Kreen is a different chemical from the previous 90k miles, right?
If I've learned anything on this site it's that changing from one chemistry to another 'will' change the consumption upon initial use. I'd imagine your consumption will settle down, but you could consider changing to another High Mileage oil brand to see if another additive composition will change the consumption again.
However, might it be worth checking the PCV valve? If this is occurring on mostly highway driving, what are the RPMs at cruising speed? That may clue you into a higher/lower vacuum service use and give an area to look for consumption contribution.
Thanks ltslimjim! I waited a while to confirm this. Yes, the post-kreen increase in consumption is highway driving only. I replaced the PCV 2 years ago with a Napa aftermarket. Its a different design. Larger opening for PCV gasses, very loud ticking. I am going to buy an OEM Toyota PCV from the dealer with the small opening. Need to rule that out.
For people reading this a clarification: I am not saying Kreen caused the increase consumption on the highway, I think it exposed the old engines weaknesses and repairs that are needed. No different than the "synthetic oil causes leaks" myth. I mentioned the engine needs valve seals in a prior post.
The point I'm raising is..for older engines with known consumption/leak issues, a cleanup may expose more problems than it solves depending on whats causing it. Try to figure out what it is before tossing chemicals in your engine blindly. If the engine is simply dirty, coked rings, no known mechanical issues, no external leaks, I think Kreen is a great additive for preventing future problems. I continue to use Kreen on other vehicles. No reported issues with them.
Will report back after testing OEM PCV for a while.
Great points! I think changing the PCV valve back to an OEM valve is a good idea. Aftermarket PCV valves have been hit or miss for me over the years. An E-150 I owned started using oil with a change to a Fram PCV valve. I tossed it, went to the dealer and grabbed the Motorcraft PCV valve and stopped using oil. That might not be the case here, but an OEM PCV valve could help. Keep us posted.
