Originally Posted by TiGeo
You mean by ~3% less than a paper filter?
Did you ever bother reading the actual report that graphic that you so proudly posted come from? Here's a mirrored copy at Nicoclub: https://www.nicoclub.com/archives/kn-vs-oem-filter.html
You also left out the graphics that show the K&N plugs up ridiculously quickly and (embedded below) that it flows more dirt through than any other (again, save the stupid foam pod filter).
Quote
The other filters, most notably the oiled reusable types, had an exponential loading response before reaching maximum restriction. These filters had a lower initial restriction, but they became exponentially more restrictive under a constant flow of dirt.
This runs counter to the "myth" that oiled media filters actually "work better" as they get dirtier.
K&N: Flows more air! Flows more dirt!
Last I checked, the purpose of an air filter was to, er, filter dirt and other particulates out of the air your engine is ingesting. Efficiency means nothing on the street if the filter won't keep crap out of your engine.
Quote
