Originally Posted by ABN_CBT_ENGR
Originally Posted by Farnsworth
No trumpets or anything,they just appear dropping out of warp speed.
Farm Bro presented some nice data on restriction and did a nice job all around. Now then, except for pictures who on here has shown any of their own home brewed performance data lately? I was glad to learn no filter is about 1 inch restriction and Wix is 4 with others in between. Then Wix wins the efficiency as would be expected.
Filter Minder seems to have a pretty good handle on what filter life is too. Takes around 20 inches of water to start looking at replacing.
Respectfully, no. I have to fully concur with "Z" here and his overall comments.
As a layman doing his thing and coming up with some really entertaining stuff, I give Farm very high marks and enjoy watching a lot of his stuff ( and he raises very good and salient points at times)
On this specific topic and issue, his efforts, tests, results and conclusions are fundamentally and fatally flawed at every level and should not be relied upon for any decision making.
This is a very well defined and understood science ( filtration) both air and fluid separation. Darcy and other equations are very well known as well as the conditions of their validity in context with the specific applications.
One of the big disconnects is that filter testing to standard is a "uniform" method of various performance parameters for various products to compare themselves against. ( basically marketing bragging rights). They are not meant to be used as direct measurements of actual applications ( the types of testing people in industries I work in do which is the next level) because that's literally an infinite set of variables to consider.
Another big problem is anecdotal conclusions as there is seldom a direct and dependent causal link between a specific parameter or test result and the "claimed" performance enhancement ( like the 1 armed bandit tests) and marketing agents exploit this regularly.
So these home grown tests need a high degree of scrutiny and even advertising claims need it when they "draw conclusions" from these "test results"
Theres a long road between raw data, evaluated data, relevant data and the actual conclusion and its rarely a straight one and almost always is condition and parameter specific.
Just submitted for a baseline on all filter comparisons be it air or liquid- the science is the same, only the specifics of the application differ.
