Wanted to change my oil but I couldn't get the drain plug loose. Long story short....the people that did my oil change last time on my Honda Fit re-used the same washer for the drain plug and overtighten the bolt. I was using a hammer to hit the ratchet to get it to loosen and it didn't even budge. I ended up rounding the bolt and that's why I took it to the dealer.
Good thing is that only the bolt was messed up. The threads on the oil pan was still ok.
My question is the oil they used had a part number of PK520. I'm guessing the 520 part is the oil weight since my Honda Fit takes 5W-20. Not sure what the "PK" stands for.
Anyone know?
Thanks!!
Anyone know?
Thanks!!
