Oil change interval
Im in Montana and the truck is garaged and not used daily, just for weekend runs to the mountains and when theres a lot of snow in winter. Our Camry is used fpr daily driving Thanks for the help guys
My wife’s garage kept Lexus ES350 gets a 3-4K mi synthetic oil change annually and a synthetic filter change every 2yrs. Ideally early spring. A used oil analysis has normal levels of wear metals and the absence of fuel dilution. Currently at 61k.
My recommendation is to use a Batteryminder de-sulfurnator connected by an enternal 12v SAE cable for a no hood opening trickle charge.
Good advise on the batteryminder. I do this and have 10 year old batteries that continue to crank away.
You could go a couple years. Just give it a 15 mile run every few weeks.
While going out for a log drive every now and then is generally considered helpful, how have you determined a 15 mile run every few weeks is appropriate?
FWIW, my Camry doesn't get used as much as it did a couple of years ago, and I take it out every now and then for a 100 mile or so drive. That will surely "boil off" any water and many contaminants, but, IMO, it's not a substitute for frequent (appropriate) oil changes.
When my 5.3L Tahoe - same engine as the Silverado - got to be 5 or 6 years old I got another vehicle - so it was not getting driven much.
I would go 1,500 - 2,000 miles a year - I started going 3,000 miles or 18 months between changes - whichever came first.
It now had 60,500 miles and I started driving it more - close 3,500 a year - now I go to 50% on the oil change monitor which is about 3,000 miles, then I change the oil but not the filter. I have about 2 months before the next change with oil + filter. The filter has 5,600 miles - the oil only 2,600. Oil still looks new.
If you search there is a guy that did some videos about this topic.
He had some low mileage per year vehicles and he ran them for way more than a year - sending the oil out for analysis and even the oil that - say had 4,000 miles over a 4 year period still tested good.
IMHO the miles is more important than the time.
