Jeep (Chrysler) 2.4L I4
Originally Posted By: Kuato
We'll be sticking to the 5 or 0w30. Thanks again--
i think that is a good choice since the 2.4L EDZ was never specd for 20 weight.
Originally Posted By: cpayne5
Originally Posted By: 440Magnum
They kept the SOHC 2.5 in the Cloud cars until it was replaced by the Chrysler DOHC 2.4L, which was later used in the PT Cruiser, but I don't *think* was ever put in a Jeep of any sort (not 100% sure on that).
The 2.4 replaced the 2.5 in the TJ in 2003. It was also available in the Liberty, Compass, and Patriot.
Well, the Compass/Patriot 2.4 is NOT the same 2.4L engine as the PT Cruiser/Cirrus/Stratus/NeonSRT4 engine. The former is a version of the GEMA "World Engine," the latter was a belt-timed Chrysler design (EDZ) that shares some dimensions (bore center spacing, general crank design, balance assembly, etc.) with the old SOHC 2.2/2.5 dating back to the 80s. The very last application of the Chrysler 2.4 was the 2010 PT Cruiser. That said, they're not ALL that different in what they do to oil, although the GEMA is chain timed so it probably has more shearing potential. The Jeep pushrod 2.5 had slider lifters until the end, so its got the same oil needs/likes as the 4.0 I6.
I'll take your word for the TJ and Libby, I've never really followed 4-cylinder applications in Jeeps that closely (and don't even get me started on the huge palette of transmissions that have showed up in Jeeps!)
All that said... The EDZ 2.4 was *never* given a factory spec for 5w20 oil. Even when it was in production along side the GEMA (which was spec'd for 5w20). I'm quite sure that it would run happily on anything from 0w20 to 10w40, and is certainly OK on Mobil 1 0w40, but the factory spec was always 5w30 for the EDZ.
Originally Posted By: artificialist
The equivalent Mitsubishi 2.4 engine calls for 10w30 in most conditions, 5w30 where cold.
This one is spec'd 5w30 preferred, 10w30 ok if over 60*F continuously.
I would use what the Factory recommendation says to use. I use 10w30 and 10w-40 Conventional motor oil of various brands in my Jeep 4.0s(Have 4 Cherokees with this motor) depending on mileage and wear they have accumulated.
