Jeep 4.0 FL-1A
Originally posted by Chris142:
Can you remove the adapter and screw the filter right onto the block?
i dont think so
if you look closely the a port for the oil pressure sender is in the adapter housing
FWIW ive had 2 4.0's one had the adapter and one had the filter right on the block. the FL1A works fine on both
My filter screws right to the block. I don't know if there's a "adapter" within the mounting pad though. For curiosities sake, I'll look the next time I change the oil.
