Neither really. It seemed to perform as before. I'm not sure what the total system capacity is, but the D&F only takes about 2.5 qts with the rest being J4.@chainblu : did you notice better or worse performance after using the Idemitsu fluid?
I've found performance is mostly due to the CVT system working properly as a whole and definitely temperature dependent (ambient, fluid, etc). Performance issues arise from fluid levels too high/low, too dirty/worn, too hot/cold. The networked control modules have so much control that it's tricky to feel what's really going on or what's not "right".Neither really. It seemed to perform as before. I'm not sure what the total system capacity is, but the D&F only takes about 2.5 qts with the rest being J4.
Sounds good! Don't forget to clean the magnets and check the inlet filter/screen if possible.Looking forward to receiving the case of Castrol Transmax CVT I got on sale for a 2012 Lancer. Going to perform a dump and fill on the kid's car. Got in on sale yesterday for $43 Canadian for case of 6. The product spec sheet lists J1/J4, which is the OEM spec.
Where did you order this from?Got the order. They sent the Universal ATF/CVT fluid, which has the J1/J4/J4+ spec listed...
Interesting, thanks for the link.Amazon Canada. The price bounces from regular to discount depending on the day, but goes on sale at 50%+ off regularly on both US and Canadian Amazon websites.
https://www.amazon.ca/dp/B00T96Q956
Got the order. They sent the Universal ATF/CVT fluid, which has the J1/J4/J4+ spec listed. Here's the spec sheet for it:
https://www.castrol.com/content/dam...max-universal-full-application-sheet-2_24.pdf
That's a pretty extensive list of compatibilities! For a 12 year old car, with over 150K kms on the original fluid it should be an improvement, and was the least expensive option at $43 Canadian for 6 quarts, $7.16/quart.
Can you post the Mitsubishi list of approved fluids please?OEM supplier is likely Idemitsu and more affordable than a dealer bottle.
Compatible means nothing if the manufacture does not have that on a list of approved fluids to use.
Someone could mark a bottle of canola oil and say its compatible, that does not mean that it is, or approved by the manufacture.
The word compatible is a marketing word to sell the product.
There is no universal one size fits all automatic transmission fluid. Unless your stuck 100 miles from nowhere and need some fluid Now.
I am not a Mitsubishi representative, so how could I do that? It is likely just the stuff the dealer sells that is most likely made by idemitsu.Can you post the Mitsubishi list of approved fluids please?
