Jack Stands
This is precisely the same question that I have. I am always reluctant to find alternate jacking point by trial and error. Sometimes you will be able to find a service manual listing the jacking point but even the picture might be clear enough for a novice.
- Vikas
There's no problem having the whole car in the air using four jackstands. Place them properly, then don't add add a bunch of weight to the nose or tail of the car(your two 200lb buddies shootin the [censored] sitting on the bumper)that could cause it to tilt.
I've had a car sit this way for a whole month while leisurely refurbing the entire suspension. No problems at all.
Diagonal placement - penny wise/pound foolish. Get four.
I've never had problems using four. I get it up on all four corners, taking care to watch and feel all four points as it gets let down. Pay good attention. I push on the car to ensure it is sturdy and isn't going to fall over easily.
If jack placement is tight I've never felt it a problem to scoot the jack over some. It is steel, after all. Just be sure it won't slip.
I'm never complacent when working under a car. I'm always as careful as can be. I'm always reading of somebody that let it get the better of him, and I don't wish to be another story in the paper.
As many times as I've cheated the tall guy in the black robes, I don't want to turn around and give him a freebie.
Originally Posted By: outoforder
I'm getting two jack stands and a floor jack to use for my oil changes. Is it safe to place the jack stands on diagonal corners in order for me to work underneath and rotate tires, or should I use 4 stands?
[censored]??? You know this is a stupid question, right? That's like asking if you should swallow iron metal because your blood test came back indicating your iron level is low.
Reposting to emphasize FOUR JACKSTANDS. LOL, just wanted to be clear.
If a vehicle is on the 4 jack stands, how much force would it need to topple? If I am not built like Arnie, is it possible for me to push from the back and get it to tip over?
Once it's up, give it a wobble and see if it'll tip. I sometimes do this as a check. Better to have it tip before you get under. Better yet, I throw a log or one of the wheels under the car for added safety.
Well what do you think the "iron" ion your total cereal is? Yes it is iron filings.
