Originally Posted by Dave9
All passenger vehicles are designed to be able to lift one corner for the obvious reason of changing a tire, unless explicitly stated otherwise. Consult the owner's manual for the designated jack points, though these are for the factory supplied jack and if you know what you're doing you can find alternate points without causing damage, which is also useful to have a redundant support point if you're not taking the wheel off to use that as your backup support, or your wheels are so skinny that they wouldn't be effective at that.
Then again, it takes maybe 30 seconds to jack up the other side of the same end and you may get that time back from ease of working under the vehicle, or less soreness the next day because you didn't have to be a contortionist to get work done. Granted an oil change is usually not that arduous a process to make as much difference as some other repairs where you don't have a lift and are working on the ground.
IME, the lifting height to get a tire off is much less than to get a jack stand, even in a low position under the car. This is the case for low-slung cars like my 135i, and high, old school ones like like my old Mercedes cars.
Its a matter of a few inches, which may not matter, but depending upon suspension configuration, and if another corner lifts to get there, might be a consideration...
