The Critic
Thread starter
Youtube is sometimes wonderful.
Those are the factory lift points...
This is assuming we are on flat surfaces and the jack stands are rated for the application.
I generally use the subframe for the front and reinforced center point for the rear. The video in @Dave9 post shows several others that I wasn't aware of.For example, on your Odyssey, where would you place the jack stands?
The factory lift points for the Odyssey are extremely sturdy from my experience so it has never occurred to me to try a different location.
Asphalt, in hot weather, can get soft. Perhaps soft enough to allow a jackstand to move.
Because they're not terribly complicated, shouldn't really cost as much as the US made do... I want to support US manufacturing, but they have to meet me half way.I think Harbor Freight offers your money back, right?Seriously though, I have no idea why people cheap out on something like jack stands.
How did the vehicle slip off? Misalignment?I don't think failure is the main issue; slipping off is. I wonder if the u-shaped ones are less prone versus the flat ones.
The only time I've had a vehicle slip off was with the flat rubber blocks used by quickjack.
Height of the rubber blocks - I had to stack two different rubber adapters in order for there to be enough clearance.How did the vehicle slip off? Misalignment?
Id say that jack stands are marginally safe, and a necessary evil. There are tons of reports of them tipping and falling. The big question becomes how much backup do you have to catch a vehicle, especially if you’re going under it?
