Hello All,
I have been considering getting a set of the 16,000 LBS rhino ramps to do oil changes on my forte/saturn.
I was curious if any of you use the newer ones on a regular basis? (I think the designs have changed a few times in the past.) I like the ramps for the ease of use when doing oil changes, but have a hard time getting under a 2000+ vehicle that is supported by plastic, IF I did get a set I would still most likely position jack stands under the car somewhere, just in case they did collapse.. A car can be fixed or replaced if the worse happened.. I on the underhand not so much....
Currently I use a Walmart floor jack that i got for under 20 dollars, and 3 ton jack stands that seem pretty sturdy from tractor supply.. But with my current jack I dread doing oil changes, I am not the smallest person in the world, and a 13~inch lift makes it just big enough so I can drag myself under the car.. and it takes forever to get the oil changed, getting out for tools, getting back under.. ect ect.. and I always have some nice driveway rash to show for it.
So what say you bitog? Get some ramps, or stick with the stands?(I could also see how stands could fail easily IF the weld wasn't done properly, so I am kind of torn on this subject.)
