Transmission Fluid Change getting vehicle level while jacked up
CA
Hello
I have a 2000 Passat and plan to service the transmission fluid /filter myself at home in my garage.
The vehicle needs to be jacked up and level to get the proper amount of fluid into the transmission
I have two sets of jackstands however they are different brands so don't think I am going to be able to find height positions that match front to back.
I do have two sets of rhino ramps and was thinking to drive the front up onto one set and then jack up the rear and put a rhino ramp under each wheel and then lower the jack. Does this should like a good idea?
Any other ideas?
Before I got my Quick Jack, I used to drive up on the ramps (also Rhinos) and then jack up the rear of the car in the center. My VWs have the structural member that connects both lower links on the subframe and I would locate the jack in the middle of this. Would jack the car up and use the level feature in my iPhone on the lower front door jamb to confirm it was level (zeroed out). Place the jackstands underneath the trailing links for safety, but kept the car level with the jack. Did this for many years without any issues when doing transmission fluid changes/fills.
Different brands could still give you the same height, as long as both are the same size :)
If you'd rather use 4 ramps, you can just drive the car on the ramps like normal. Set up the rear ramps the same way you set up the front ramps. Stick the ramps under the rear wheels, just like you do with the front, and then drive up :)
thanks but I don't think that I will be able to get the rear ramps under rear passenger door area as I don't think there is enough clearance even with the low profile rhino ramps
I know everyone can't get away with this but the Volvo transmission fluid has no dipstick, you have to get it level, get it to temperature then bleed the excess.
We have to do the same in the Toyota, I usually just put the tires back on and remove the jack to have the car on the floor.
But I can still reach the drain plug when it is at the proper temp range to drain the fluid till trickle.
Not sure if that is possible for your car.
The key is, the floor have to be somewhat flat not on an incline.
Many lifts in shops aren't lifting perfectly level and this is performed regularly.
Do the math on a 1* degree slope from left column to right column ‐- esp on a lift with extra drive-thru clearance like mine.
Then factor in imperfect lift pad adapter heights at the frame and variations in the framerails of trucks and it's a wonder any vehicle serviced on a lift can move under its own power at all ‐‐ or is it????
IOW people like to overthink is. Eyeballing level is good enough.
Check the level of the existing fluid. If it's in the correct range, just measure what you drained out and refill with that quantity.
No need to overcomplicate this.
I do the double set of ramps trick and face them in the opposite direction. Makes it a bit more secure and makes me feel a bit better about being under it and I know its reasonable level for what I'm doing.
  • Like
Reactions: D60
what is the ramp trick with them facing in opposite directions. Could you please send a photo thanks
I don't think I have ever taken a photo of it. But essentially you drive the car onto the ramps with the front lifted. Then jack up the back of the car and place the second set of ramps under the tires with the ramp angle facing the front of the car. So the car cannot be driven froward or backward without falling off the ramps. In the case of Gorilla ramps, there is a lip, so the tires cannot roll off the ramp. This secures the car from moving. Works nice for a small car like our Beetle. Big SUVs or trucks have tires large enough to rollover that lip, so its point less on those. I'll try to take a photo of this Rube Goldberg setup next time I do it. Its at least worth the laugh. :ROFLMAO:
I went through similar with my 2007 Jetta. I cut down some 2x10s into 15" long sections stacked 4 high and screwed together, plus a piece of 2x4 across each end to act as stops for a total 7.5" tall wheel cribs. One for each wheel.
It has to be done this way since IMHO there's no good place on the pinch welds to jack the car and place jack stands simultaneously at the factory lift points. Anyway it worked out perfectly as I've changed the filter and did several spill and fills with this setup. I'll try to get pics of the cribbing if you'd like.
Same, just stacked pieces of 2x10. I cut pieces for 3 levels, drove up 2 levels then got out and put the third level on. I didn’t screw them together, just stacked them, easier for me to store.
