Trust Rhino Ramps?
I have about a ten year old set of the largest Rino's, and within their limitations, they work fine.
I personally prefer a trolley jack and jack stands, but starting with the '04 Jaguar and '04 GTO, those cars (and the Solstice and the G8) were (are) just too low to the ground to get my trolley jacks under.
As noted, on smooth concrete, they will slide. I had an area of concrete in the floor of my little car shop roughed up to stop this. Second, the vertical height is not that great. With modern cars with 17 and 18 inch wheels, it's not that bad, there is room to get under the car on a creeper. But on older cars, like my '94 Jaguar that has only 16 inch wheels, and sits really low on them, it can get tight. I still prefer to just use a couple of trolley jacks and stands on that car. Third, if you need to do brakes or something that means wheel removal, you still have to have a trolley jack and stands to get the car up off the ramps. Fourth, if the car don't move, it ain't going up on ramps.
Even with the V12 Jaguar, I've never worried about their weight limitations. I've never felt the need to put a secondary set of support under any car when it's on the Rino's. I do chock the back tires, however. I've personally seen metal ramps buckle and I would never trust those without a secondary means of support.
When I build my next shop, I think I will go with a post lift.
Originally Posted By: Pop_Rivit
Originally Posted By: actionstan
Get some ramps, or stick with the stands?(I could also see how stands could fail easily IF the weld wasn't done properly, so I am kind of torn on this subject.)
None of the above. I have a KwikLift that I use-when it's down it provides enough height to comfortably do oil changes, and when it's up it's high enough that I can sit under a car/pickup and work on something without laying on my back. All the while the vehicle stays level.
I also don't have to worry about plastic ramps.
What about if you need to remove wheels on an axle to do suspension work?
Put the centerlift bridge in place, and use a bottle jack along with jackstands. Or, if the vehicle has suitable jacking points, use a bottle jack directly on the ramp, along with jackstands.
The ramps give you a perfect place to sit while working on suspension or brakes when a wheel is off.
Thanks but I'm not quite picturing how this works practically. Some/many cars are too low to lift with a bottle jack. Driving up onto this lift doesn't help that situation, as the bottom of the car is still the same height with respect to the point where the bottom of the tires are. The lift that you drive on is still the "floor", right?
I'm in the market for one lift or another, at some point. Ever park a car on it?
I have the ramps. If I wanted to be extra careful and use jack stands also, where would I place them? I also see the possibility for the car to roll back off the ramps?? I don't think extra protection would matter much then.
Chock the tires that are on the ground, put an automatic in park, a stick in first, and set the parking brake. The car "shouldn't" be able to roll backwards off the ramps.
I love my Rhino ramps.
Have the 12,000 set for when I need to be under the Outback. But since I can change the oil, ATF, and rear diff without having to lift the car (yeah, ground clearance!) this only for front diff or some repairs. Or when I work on a friend's car.
