Might be moving to a garage that isn't long enough for my current method of getting all four corners of the car in the air (hydraulic jack under the front, place jack stands, repeat in rear). So, I need a new way to get all four corners up.
Jacking from the sides with the same equipment isn't really an option because the jacking points are also the only good places to put jack stands. Scissor jacks might work in theory, but I'm not comfortable getting under a car supported only by those. Plus, it'd be annoying to have to work four of them at once.
A real 2-post lift is not an option, unfortunately.
Looking at these right now: https://www.quickjack.com/ Seems like the best solution, but I'd prefer not to spend that much if I don't have to.
Any suggestions?
Any suggestions?
