I use Amsoil Universal ATF in my '04 4Runner without any issues whatsoever. The transmission shifts smoother and seems to be a little quieter than with the T-IV fluid. Another good choice would be the RLI Bio-Synthetic ATF.
Quote:
T-IV and drain and fill every 15-20k miles. pretty simple and it works well
Quote:
With that mentality, I might as well change my oil every 500 miles.![]()
Quote:
Are you suggesting that changing ATF every 15,000 to 20,000 miles is overkill?
Quote:
Causes can't be traced to frequency of fluid changes because there weren't ANY.
Many transmission failures that I've seen can be related directly to lubrication.
Quote:
how much is Amsoil Universal ATF? and this oil meets or exceeds Type T IV specs right? it says on the bottle?
Quote:
YES. I quite certain that if one truly analyzes the cause of failure for most of the units made within the last five years, the cause cannot be traced back to the frequency of fluid changes.
Fluid changes are really a peace-of-mind. Their benefits are very questionable when performed at a more frequent than recommended frequency.
Quote:
Critic, and there is no proof to the opposite.
So, my experience shows that maintenance(called PM) works. And, I have more years of experience then you have years of life. Post back when you're not a teenager after 20 years of manufacturing, mechanical, and industrial experience(even though I wouldn't recommend that career field for anyone these days).
If you want data, get a job in ANY transmission shop. And, question every owner of every vehicle that comes in. You'll get that data very quickly.
