T IV Automatic Transmission Fluid
Federal Way, WA
I recently purchased 2003 Toyota Corolla LE
the owner's manual calls for type T-IV ATF.
Also indicated in the manul saying, if you don't
use type T-IV ATF, it could damage the automatic
transmission.
Does any member know what kind of ATF is the
T-IV AFT??? Help
jsleesi
I've read on here before that this fluid is "proprietary"
to Toyota and they aren't saying what it is (or what is in it). I would use it as to not void the warranty.
Seems to be a trend among all Asian (European, too?) manufacturers to specify their own proprietary fluids, now. Mitsubishi and Hyundai/Kia specify the Mitsubishi SP-III ATF. (Mitsubishi hasn't released the formula or offered to sell licenses, either, though somebody in the U.S. is making it for Hyundai/Kia.) I emailed Lubegard to clarify their position on the SP-III issue in advance of my 2003 Sonata's first ATF change at year's end. Lubegard's response was to use Mobil 1 ATF with the recommended dose of Lubegard Platinum. Given my past experience with using Lubegard HFM in my '96 Accord, I have no doubt that it would work, but, frankly, it'll be cheaper to just buy 8 quarts of SP-III at my local Kia dealer. (They're a buck cheaper/qt. for the same part number than my Hyundai dealer - and closer!.
) Hyundai recommends 105,000 mile ATF changes, or at 30,000 miles for "severe service". I'd still like to get the factory-fill fluid out no later than 15,000 miles, though, then maybe every 20,000 miles thereafter.
I suspect the Asian proprietary ATFs are very, very highly friction modified and rely on some percentage of Group-III base stocks. I just wonder how may of them are actually compatible with each other. Be a nice experiment for someone else to try...
LOL....and it ain't going to be me!!
BTW my 2002 Sportage 4x4 actually uses Dexron IIE (III).....
It's my power steering that uses some type of special fluid....it's probably just that "special" transmission fluid in a different bottle......
it's called PSF-III ir something...
