http://www.9thgencorolla.com/forum/showthread.php?t=84143
Originally Posted By: Batojiri
Castrol import ATF works fine in our cars, i had it in my car for 30,000 miles and never felt any weird vibrations or heard any noises and actually kept the transmission a little cooler than the stock oil because its slightly thicker and soaks away heat better when using a transmission oil cooler.
only one ive used it in was the 2006 Toyota Corolla S i have right now and i had it in there for 30,000 miles before i went and got my 60,000 mile transmission system flush. but i loved it when i had it and didnt seem that much different than the original T-IV i had in when i got the car before i had to change the stock oil out at 30,000 miles. the temperature of the transmission oil seemed to be a little bit lower when i put the Castrol in than the stock fluid though which means it helps promote heat dissipation through the transmission pan better than the stock fluid.
