Originally Posted By: SteveSRT8
We routinely run larger American V8's to failure here. Mileages range from 200k to as high as 500k miles and almost all are disassembled by me personally and inspected here before going off to my BIL for remanufacturing at his shop or being sold as parts.
I have never seen any engine as clean as Trav described at 200k miles. Ever. Started tearing engines apart in 1968 with my Triumph TR-4, and have done quite a few since then!
Every single piston I have seen at over 100,000 miles of real world use has had deposits visible on it, and junk in the rings. Not all were solidly coked into immobility, but ALL were visibly soiled with deposits.
I believe that such an engine as Trav describes represents an exception, not a rule of thumb.
Good to know--I haven't torn down or built an engine since 1992. Guys--what would be your correlation between deposits under the valve cover to deposits in the ring area? Like--would it be mostly true to say, if it's clean up top, it's clean in the ring land area--
What are your observations in the ring area at 150K miles or 200K miles ?
Steve
