Is this a thick/thin 5W30?
quote:
Originally posted by sprintman:
cSt @ 40C 70.11
cSt @ 100C 11.05
HTHS @ 150C 3.23
VI 145
TBN 6.2 (ASTM D-2896)
Flash 221
Pour -42C
A little on the "thick" side. Mobil 1 5w30 is around 9.8 cSt @ 100°C. I'm surprised the HT/HS isn't better, though. Mobil 1 10w30 and 5w30 are both thinner than this oil at 100°C, yet their HT/HS numbers are about the same: 3.2.
This is not an A3 rated oil, that's for sure. What is it?
VI looks a bit low, but a good pour point. I assume the CCs is no more than 6600Cp@-35 or it couldn't be called a 5w. 11.05@100C is slightly thich compared to many others, which run between 10 and 11.
Lubrication Engineers 8530 Monolec SPB 5W30, which I'm considering trying in my Sube Outback with RX maint dose. Looks OK I thought for a blend?
I suspect this oil is going to shear (possibly out of grade) rather rapidly. I hope you'll do a UOA and post it. The results should be interesting.
Wasn't there some speculation, though, that a lower VI tended to correspond to a lesser amount of VIIs, thereby potentially allowing for greater shear stability? Or do I have that backwards?
quote:
That is my theory, but it only pertains to fully synthetic (PAO/ester) oils. Not conventionals, and not blends.
Just spoke to LE and 5W30 not imported. 10W30 Monolec Ultra-Blend is but A$90 for 5-litres. Hmmm BP Visco 5000 5W40 PAO is only A$129 for 20-litre drum, I'm having second thoughts.
