They start fine without it, and if you check pressure in the fuel injection line, youll find it with the car off (most likely...).
That said, all my cars including my DI vehicle, all make a bit of fuel pump noise in the on position, so it does at least spin up a second. Its one of those cant hurt things...
A related note... I had heard more than once that one should turn on their headlights before starting the car, so that the battery could start moving some current. That is counter intuitive to me, since then the battery will have a lower voltage under load. But I will say that the key sitting in on for a second has the same sort of effect, likely in a more beneficial way (e.g. heating the O2 sensor), so isnt a bad move...
