Originally Posted by Gokhan
Originally Posted by KCJeep
Curious if you know whether PAO stands up to turbo abuse better than all Group III oils. I do 10k OCIs on the Tiguan and have already purchased some Valvoline Euro 5w40 for it's upcoming change, but as far as I know it's Grp III entirely and later I got to thinking (the BITOG curse).
I can dump the Valvoline in the Kia no problem it's about due as well.
Only readily available Euro oil with significant PAO I can think of is Castrol 0w40 (what's in it now) are there others?
Thanks
If everything else is the same, PAO is better of course because it has higher oxidation resistance. This results in longer oil life and less engine and turbocharger deposits.
The most-demanding specs like the Euro-OEM 0W-20 oils tend to use PAO.
The add pack still needs to be good and compatible with the base oil though.
Don't forget about POE and AN.
Castrol 0W-40 is about one-half-PAO. There is no POE or AN. The rest is Group III.
M1 0W-40 is about one-quarter-PAO. The rest is mostly GTL (Group III+++) and up to about 10% of the base oil is POE. POE can make a big difference in turbocharger and other demanding applications, as it has a very high cleaning power.
I would go with M1 0W-40.
Not according to this SDS:
https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-fs-0w-40/
Thanks
