Just installed an oil temp gauge in my autocross car. Its in the bottom of the sump.
Took it for a ride last night to see where it wants to be and it stays between 150-160⁰. Even when I let it sit and hot idle for 15min at a friends house it only got to 160⁰. Came down to 150-152 nearly immediately when I started driving again.
Current oil is HPL pcmo 5w30. The car runs a front splitter that goes to the axle line however the fan for the a2w intercooler does run all the time and is immediately in front of the motor. Cooling system hangs out around 190⁰. Oil pan is modified with trap doors and has about ½ quart added capacity over stock.
I guess ultimately I really cannot do much about it. Next event is in a couple weeks but I cannot imagine oil temps getting much hotter.
A customer of mine with a 4efte Starlet runs around the same temps...maybe 5-10⁰ more at most. Same sensor location and same brand gauge.
