hey all, vehicle in question is a 2015 rav 4 automatic. i am currently on a roadtrip and when i used to be back home in the south i never had troubles with tranny shifting when cold or hot however ambient temperatures early morning were easily minimum 70-80f everyday which i assume means the fluid was always good to go
however ever since i been in the north for past few days, if i start the car in the morning around 50f it feels slow on shifting and feels like it takes longer to engage and or sometimes jerks however once it warms up after 6-8 mins of driving it feels good as new (which is around the time my engine coolant temp reaches the middle), however lately when i left in the morning it was 42f and it felt slower and worse then 50f. when i start the car and put it into drive or reverse it does so instantly and feels fine at idle. however when i drove it cold when outside was 42f it felt delayed/sluggish again
however once again it felt fine and like normal after 6-8 mins ish
is this normal for cold temps? or is 45f ish not cold enough for it to act like this? i had my fluid changed 6 months ago and never had any issues in the hot south. i set the level as close as possible to the manual, it must be within 100ml at the worst compared to perfect spec
just tryna to figure if this is normal or if this is a symptom of low level? no dipstick so i can't check easily
thanjs
thanjs
