Originally Posted By: rclint
demerpaint I did use a poor choice of words when I said absorbed, but plated, and coating are also really not correct.. Again if I remember my research correct the moly will bond with the substrate attaching itself.. I will have to do some more research so that I can post the correct info...
I'm scared to say what moly can do as I have not run any trials adding moly to engine oil... I wanted to give my experience on what moly can do which is build up a layer on top of itself which will become an abrasive instead of the outstanding low friction benefits we expect, and read about from moly. I do know a 5 quart or more of engine oil, even in a hot sump is a very poor carrier for moly meaning that it's just a poor way to deliver moly to the internal engine surface, however it's pretty much the only way.. Also the only way I know of to do test on this type of moly addition would be extensive tear downs, I love doing test, and I love experimenting with a true scientific point of view... but not to the point I want to do tear downs on an engine just to see !!!
The bad thing I can see about moly in the engine oil is even though the oil is poor at getting the moly where you want it to the internal engine parts... it would be outstanding at washing this moly off with the moderate warm engine temperatures, I'm sure vast amount of cleaning additives in the oil.. so it would be a fight even if you got it to where you want it... I'm still out on a limb as to if I think the moly offers a value in the bottle as you are talking about, and I would be worried about the moly building up just because that's what I have seen BUT NOT in a engine..
If I were to guess how moly would help an internal combustion engine the most I would think if the engine has a timing chain that moly would be great in this application as the crushing, rolling action of the chain would really be a great place for moly to bond to. Flowing oil over a surface even if hot is not a great way for moly to bond to...
I will try to find some websites to help me explain if I'm still being hard to understand... a couple of nights on third shift puts my brain of the fryer... and I will have to be up all day... so don't give up on me I will find some websites that explain how moly bonds to metal, and the best ways to deliver it .. and the best way to get the moly to bond with the metal substrate once it gets to where you want it. Also I'm no oil guru, I have been learning huge amounts from the great members here, and my views may clash with others at times, but i try to keep an open mind... so what I'm saying is demerpaint said it perfect when he said the part about redline knows enough about moly to establish a safe, and effective amount of moly... keep in mind redline also probably knows what additives work best with moly... and I'm sure their are many different grades of moly as well...
Posting opinions, observations etc are what this board is all about. I was just trying to clear up certain phrases you used that's all. I'm far from an expert myself but do a fair amount of research before pouring something into a good running engine.
I think what you said about moly having benefits in timing chains could be true. I was thinking more toward bearings where a thin film of moly might be a big help. For a respected company like RL to be using it means to me they must have extensively tested it and feel it has value. Lubro moly is using a moly suitable for automotive applications. You could always contact them and ask questions directly to them, they are not pushy and eager to help. At least that has been my experience with them.
