Hi,
Well, I'll share my story...
First, I use Pennzoil (at .69-89 cents a quart) and Motorcraft Oil Filter for $2.77 for my oil changes. Less than $7 for the total for a oil change.
About a year ago, I had Terry do a UOA on my 1999 Ford Taurus that I just changed the oil. The car was coming up to being 3 years old and had 61k miles on it. (The orginal and ONLY warrenty is the factory 3yr/36k)
It came back with a *slight* coolant leak that had not done any damage that we could tell on the engine. I was not having to add any coolant and the car ran fine. Terry had me go check the coolant for oil and yep, we have a Head Gasket Leak.
Over $1100 later and 2 rebuilt heads the car was fixed.
I went to Ford and after a lot of Dancing, they covered 90% of the cost and the Rent-a-car.
How did I get them to cover most of the cost? I showed them that I take care of my cars, change the oil and if I was someone to thrash my car, why would I spend $25 for a UOA over the Less than $7 oil change.
The car (ANY BRAND) should not require heads to be rebuilt and gaskets at 61k intervals...
So, its more than a hobby in my world. I don't check every oil change now (I change every 3.5k-4.5k which is every month to 6 weeks) but still will get the UOA here and there. I think in my mind, I'd rather use a good oil and change it more often and spend the $$ saved on the oil on UOAs.. Then I get the protection and KNOW whats going on...
Oh.. Terry is the man!
Take care and thats my 3 cents!
Bill
