I don't think that a bypass setup is worth it for ATF(or even oil in most situations). Its tough to way the cost/benefit vs. using a quality synth with reasonal drain intervals.
Heat is more of an issue. Since your not in a desert area and I hope that you won't be towing, the stock cooling setup should be sufficient especially using a quality synth (or even OEM ATF).
Do regular drain/refills(every 6 months). Use Amsoil universal or Redline D4 ATF.
Pick a quality synth motor oil too. Don't forget the PS fluid. It can be siphoned/refilled during normal maintenance. Brake should be bled yearly. If you do the maintenance yourself, speedbleeder are a good investment.
I expect the Echo to last a long time.
