Originally Posted By: ARCOgraphite
. . . May yaris is 5w-30 and HEAVIER.
That is NOT correct. Here it is from the Toyota TIS maintenance pubs for the 08 Yaris.
Nothing there about "heavier". BTW, the NZ series engines, some of them anyway, have a habit of diluting their oil with fuel. That would be the most probable reason Toyota has declined to prescribe 20 wt oil for this engine series.
It usually need a little 1/2 qt M4T in there for high speed highway.
I have not seen anything in the pubs about adding motorcycle oil to the crankcase of the 1NZ series engine. I guess all the other Yaris owners missed it too which would explain all the broken down Yari I see on the roadsides here. . .
But I drive 75-85 typ on my 1 hour commute. AFA CAFE goes, only N.A. use the 20wt AFAIK.
So do I. No problems.
We just lost our rav4 engine to the Toyota service centre putting 20wt in and I'm [censored]! WAS a wonderfull engine. only 50K miles.
Even if you beat the heck out of it on 20 wt oil, it would still last longer than 50k miles. Please scan and post the diagnostic report indicating that the use of 20 wt oil killled a Toyota engine for which 20 wt was specified.
Read that TSB carefully, it doe NOT say you can back spec the oil weight on older models - you HAVE to use the 5w-30 as the lightest grade if that is what is on the CAP and manual. Period.
Yes, by all means, you should read TSB EG018-06 very carefully. And note how it sets out Toyota's position regarding 5w-20 oil, as in:
Quote:
ILSAC GF–4 SAE 5W–20
This oil has been set as the Toyota genuine engine oil, starting in February 2006 for the U.S. This oil is superior in terms of fuel economy,
engine protection, and cold starting performance. (emphasis added).
I would be leery on your 09. Lost a new KIA to 20wt back specing and our new Subaru has a rod knock, day-1 on 20wt. SO MY junkyard is littered with 20wt casulties, Now ford hond thats a diff story. They know how to build a 20wt engine.
I guess that you're just the unluckiest guy in the whole CAFE zone. . .
