First: someone above said why use/blend this oil with thinner oils. It was dirt cheap.
Below is the data I collected for blending M1 15W-50 EP with two different oils: M1 5W-20 and Synpower 5W-20. Blend viscosity at 100C was defined as 14.0 cST...my engines use thicker oils than most. You choose whatever blend viscosity you want.
Viscosities:
...........M1 15W-50 EP...M1 5W-20.....Synpower 5W-20
100 C.........18.............8.8...........8.65
40 C.........138.............48.3..........48
HTHS.........4.6.............2.62......?, but VI is 160 vs 163 for M1 5W-20
Results:
Ratio (%)....100-X..........33.47.........32.63
Blend 40 C...................95.12.........95.77
Blend HTHS *................3.8............?
Blend VI...................skipped.........150
Notes:
Ratio is to get 14 cst viscosity at 100C
* Calculator does not accept 150C temp nor take into account shear rates so accuracy is unknown
Quarts of each oil to use in two of my engines.
........................GTI.....G35
67% of sump (qts).......3.07....3.34
33% of sump.............1.53....1.67
How much 5W-20 I should buy and cost of blend:
I have 10 qts of M1 15W-50 EP
# of qts. of 5W-20 to buy...4.7952, so 5 qts.
Cost of mix ($ per quart)...$2.49
Link to the blending calculator I used:
http://www.rohmax.com/rohmax/en/customerservices/calculationtools/baseoilmixtures/
