"""And to meet GF4 standards"energy conserving" both 10w30's and 5w30's must lose viscosity. It is designed in so that the oils can pass the economy test.""
Not to my knowledge EC is normally met by running vis to low end and using good FM's. There is no shear down to a percent or certain number to qualify as a EC oil. If so i'd love to see this since I have heard this ststed before BUT know of NO such verbage in the API testing. That is why a FULL syn with little to NO vis/shear reduction can qualify as a EC oil.""
It is not a "requirement" in that this aspect is not measured, what is measured is overall performance and effieciency of the oil at differnt stages of use.
Perhaps the viscosity loss is not due to ILSAC requirements but rather a result of them to pass the aged oil sequence tests. I am making an assumption(so if I am wrong on this dynamic please correct me) that friction modifiers lose effectiveness with age to reach this conclusion in theory.
In order to match the lower friction characteristics of the reference PAO's used in the sequence tests some loss in viscosity is needed as friction modifiers become less effective.
It sounds logical to me but I am not a lube oil designer..just a hapless enthusiast who is too caught up in oil
Edit to add it is sequance VIB that I am referencing and by proxy the sequence IIIGA may impact the formulation
ILSAC GF4
ILSAC GF4
