Am I right that this filters 20um at 95%
Product Specifications
Part Number: 51516XP
UPC Number: 765809216938
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Wire-Backed/Synthetic
Height: 4.828 (123)*
Outer Diameter Top: 2.921 (74)*
Outer Diameter Bottom: Closed:
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: B2=20
Max Flow Rate: 7-9 GPM
Operating Temp. (min): 0
Operating Temp. (max): 0
Capacity: 0
Filter Area: 0
( )* denotes metric
Gasket Diameters
Number
O.D.
I.D.
Thk.
Attached 2.734 (69)* 2.43 (62)* 0.226 (6)*
Principle Application:
Principle Application: Ford/Lincoln/Mercury (81-09), Chrysler/Jeep/Mitsubishi (02-09), Various Mazda (94-15)
All Applications
Loading...
Service: Lube
Type: Full Flow
Thread Size: 3/4-16
Beta Ratio: B2=20
Capacity: 0
Filter Area: 0
( )* denotes metric
Gasket Diameters
Number
O.D.
I.D.
Thk.
All Applications
Loading...
