Hi, been looking at the spec of the filter used on uur European renault diesel.
The standard filter would be a Fram PH5976 or WIX 57207.
If we look at the spec of that filter:
Part Number: 57207
UPC Number: 765809572072
Principal Application: Various Renault Trucks - Lombardini Engines, Arctic Cat
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.418
Outer Diameter Top: 3.071
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Max Flow Rate: 8-10 GPM
Nominal Micron Rating: 25
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
A slightly oversized replacement that looks like a exact upgrade is the Fram PH5566 or PH5566A or WIX 51083
Part Number: 51083
UPC Number: 765809510838
Principal Application: Melroe Bobcat, Toro, Yale & Towne Forklifts
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
By-Pass Valve Setting-PSI: 8-11
Burst Pressure-PSI: 280
Nominal Micron Rating: 21
Gasket Diameters
Any thoughts or help appreciated, apparently the bigger one used to be used on older renaults, so i am guessing its a good choice as a slightly larger filter for the job, but i am guessing.
Part Number: 57207
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.418
Gasket Diameters
Part Number: 51083
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Gasket Diameters
