Wix 33247 Fuel Filter options
Alberta, Canada
Sorry if this isn't the correct area for this post. I am wondering if there are any other alternatives to the Wix#33247 Fuel Filter? Maybe a little taller, or even with the drain on the bottom? Here are the details, Thank you in advance.
Height: 3.404
Outer Diameter Top: 2.939
Outer Diameter Bottom: Closed
Thread Size: 13/16-18
Beta Ratio: 2/20=3/11
Burst Pressure-PSI: 275
Max Flow Rate: 8-10 GPM
Nominal Micro Rating: 14
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.120
Got me swinging.
It's got no x'ref in Baldwin, Donaldson, Hastings, Fram, or Purolator
filtermart.com has about 8 numbers that puke out of its search engine. There's something wrong with their link to actually get the dimensions.
BUT!!! All of their numbers are extensions of your primary part number. That is, 332471 ..all the way up to 332479
So, near as I can figure ..they have 9 different offerings in that basic filter.
Now going by the filter thread, Donaldson has some offerings:
P550219
Here's one with a water separator
P558040
SPIN-ON FILTER WATER SEPARATOR/RPLC P558040
Fuel Filter Water Separators Product Attributes
A - OD (Inches): 4.28
B - ID (Inches): 13/16-18
C - Length (Inches): 8.84
D (Inches): 2.83
E (Inches): 2.45
Product Type Description: FUEL/WATER SEPARATOR SPIN-ON
Primary Application: MACK ENGINES
Substitution: P550219 Standard Fuel
This is a Wix ...
Part Number: 33419
UPC Number: 765809334199
Principal Application: Mack Fuel/Water Separator w/Drain
All Applications
Style: Spin-On Fuel/Water Separator Filter
Service: Fuel
Height: 8.689
Outer Diameter Top: 4.282
Burst Pressure-PSI: 325
Nominal Micro Rating: 12
Gasket Diameters
Attached 2.860 2.500 0.220
The gaskets are slightly different
Part Number: 33357
UPC Number: 765809333574
Principal Application: Case, Consolidated/Cummins Engines (12 Micron)
All Applications
Service: Fuel
Height: 6.081
Outer Diameter Top: 3.710
Burst Pressure-PSI: 315
Gasket Diameters
Attached 2.834 2.462 0.200
Packed 1.046 0.770 0.186
Here Donaldson
Just put the thread pitch in the SEARCH field on the upper right.
I think that you can run those numbers into the other xref's and get some other options. If you use the Donaldson numbers you get stuff out of Hastings ..the only one I went back and checked.
