Not only are EV drivetrains less complex but they are more modular at subassembly level than ICE. We already see that batteries are being replaced as entire assemblies, same applies to the motor, gearbox, on-board charger and inverter, the only other essential components. These are literally bolt in / plug in parts and DIY is entirely possible.Electric cars much less complex? I wouldn't say that myself. ...
Repair or recycling of those subassemblies will be carried out by specialists, not by your dealer's service department, just like engine rebuilding has been for decades.
The "issues" were only serious in that they were dramatic when a failure occurred. That should not distract from the root cause, a simple manufacturing mistake by LG, hopefully never repeated. The biggest hurdle was for GM, Hyundai and LG to actually accept that this would cost them an arm and a leg to fix properly. Both tried software fixes first, which helped but were not 100% effective.This may be so. But don’t forget the complexity of batteries themselves, like the serious issues with the LG batteries in the Chevy Bolt.
Sure, about 1200 full-charge-equivalent cycles down to 80% of the original capacity, which, when multiplied by the EVs range leaves you with a fairly long life.Even if they aren’t subject to sudden failure, every battery has a finite number of charge/discharge tolerate.
