It will be about $3k for the timing belt kit, plugs and valve adjust over here.Timing belts are predictable. $800 at a local mechanic for OEM parts (Timing Belt, Tensioner, water pump, oil seals) and labor.
Wow that's quite a price disparity. It sounds almost like comparing estimates for painting and paperhanging here on L.I.It will be about $3k for the timing belt kit, plugs and valve adjust over here.
I'm in no way advocating for Amsoil but, I did find this concerning Liqui MolyI'm not trying to stir up an argument here, but this caught my attention. This is not the first time I've read something like this.
https://blog.amsoil.com/amsoil-crushes-sequence-iiih-engine-test/
"When a competitor’s oil easily passes an industry-standard test, they often reformulate to reduce cost and performance to where it barely passes the test."
apparently not.....Sports analogy; All you need is one more run/point/goal than the other team for a win.![]()
Since there is zero published data comparing actual oil performance, what incentive is there to crush the tests unless that’s your angle like most of the boutique vendors?
#OilicelugeislyfeNow we have Project Farm.
Its good oil but I dont trust an oil that refuses to get officially licensed by a manufacturer.I'm not trying to stir up an argument here, but this caught my attention. This is not the first time I've read something like this.
This is an honest question… do you know the cost of the tests required to pass an oil certification? Now, do you know how many quarts of a given product the mfr sells? Since I have no clue but have seen 7 figures mentioned by those who had done or participated, let’s do some math.It’s good oil but I dont trust an oil that refuses to get officially licensed by a manufacturer.
I'll just say that every time I've brought up AMSOIL Signature Series to any mechanic, they rave about it. This has included two shop foremen at dealerships and independent shops. Getting a sticker doesn't mean much to me as someone who wants top-notch oil.
Yep. This is why I respect what Ravenol does. I may give VST a try once the SP formula hits here.This is an honest question… do you know the cost of the tests required to pass an oil certification? Now, do you know how many quarts of a given product the mfr sells? Since I have no clue but have seen 7 figures mentioned by those who had done or participated, let’s do some math.
In our completely arbitrary example, let’s pretend Amsoil sells 10,000 quarts of SSO, and the testing cost is $1,000,000. That’s $100/qt to license that oil. That’s even ignoring the dexos license fee of $0.09/qt. At 1,0000 quarts, it’s $1.09/qt in fees, and at 10,000,000 quarts, it adds a mere $0.20/qt.
This makes it super simple to see why low volume oils rarely pay full certification tests, and also why almost every shelf oil for PCEO has it; can’t have the competition with a high-volume “extra”, yet $0.20/qt is insignificant since they will just bump the price $0.50-1.00 to make their expected profit point.
At this point in 2023 your lack of trust isn't backed by any measure of real-world use experience by many Amsoil users. Do you not trust HPL because of the same reason? I get the desire for tested/approved oils BTW but trust with these two companies isn't at the root of it.Its good oil but I dont trust an oil that refuses to get officially licensed by a manufacturer.
A company called High Performance Lubricants.Can HPL be added to the acronym list, first post?
