Certain mineral oil properties eluded by synths?? like sludging or coking the turbo bearings
Which engines don't respond well to synthetics?
What turbo makers know about synthetics: less rebuilds + longer lasting turbos = less sales!
Dookie, don't worry about the synthetics. Use the 20w50 synth. For winter, there are 10w60, 15w50, 10w50 and 5w50 synthetics that will flow better during cold 1st starts.
You should monitor your oil temps.
With the turbo, oil temp will be higher. At a higher temp, the thick oil will thin some and may not be too much thicker than the 30wt at non turbo temps.
