Originally Posted By: turtlevette
Then the Porsche testing is relevant to you,
I believe that kind of testing and certs are pass/fail. I'm making an argument that simple wear testing has value for the hot rodder but I don't think you are getting it.
Oh, I get it. But I think you are ascribing far more value to what these "tests" show than what it actually translates to in application. Which is why I'm harping on the OEM testing regimen thing, LOL!
Basically, if the OEM testing protocol has set the bar high enough, the things you are trying to test for become a non-issue. That's what I'm trying to point out.
There's no shortcut to determine the outcome of tear-down testing. That's why it is still employed in lieu of these bench tests, which, I will note, DO actually have some practical uses in their intended applications, like for gear oils and greases.
Don't get me wrong, I certainly understand the allure of the personal nature of bench tests and feeling you are doing something "more". But I've also seen my share of engines apart and what I've seen generally supports the fact that using an appropriate lube for an application changed at a sane interval is all that is needed. With the added qualifier that if you are doing a flat tappet mill with an aggressive camshaft that this plays into your lubricant selection as well.
