Hello Everyone,
Vehicle:
Suzuki Brezza
ODO: 40,000 KM
Oil used so far - Mobil Super Maruti Genuine Diesel Oil 5W-40. This is the only oil that is permitted in the warranty period. We do not have consumer protection laws in India like the USA
OCI - First oil change at 1000 KM, after that an oil change every 10000 KM
Recommended oil spec- - 10w40 or 5w30 ACEA A5/B5
Engine:
Fiat 1300cc miltijet diesel, 90BHP
EGR is present, no DPF or SCR
Purolator filter, no good quality filters are available in India
Oil Capacity - 3.5L
Fuel:
BS IV diesel
Sulfur max 50ppm
Full fuel specification
Driving conditions.
The lowest temp the car will see is 15C i.e 60F
OCI 5000KM or 8000KM hence forth
60% city (can be characterized as severe service) + 40% highway ( 90-100kmph max speed. at 80kmph engine will be runnning at 1800RPM, red line is 4500RPM)
Good Oils that I can get easily.
1.Shell Rimula R4 - 15W40 - API CI-4; ACEA E7, E5; Datasheet
2.AMSOIL Heavy-Duty Synthetic Diesel Oil 5w40 - API CK-4;ACEA E9, E7 Datasheet
3.AMSOIL Signature Series 5W-30 - ACEA A5/B5; Datasheet
4.Mobil Delvac 1 - 5W-40 - API CI-4+; ACEA E7/E4; website
5.Liqui Moly Touring High Tech 15W-40 ACEA E7/B4; datasheet
What oil from the above list would you recommend.
Can I run the Rimula R4 or the Liqiui Moly with an oci of 6000KM? they much cheaper than the other oils
Cost of the oils
1. Shell - 250 INR/L - 3.5$/L
2. Amsoil Heavy-Duty Synthetic Diesel Oil 5w40 - INR 600/L - 8.5$/L
3. Amsoil Singature - INR 1000/L - 15$/L
4. Mobil Delvac - INR 800/L - 11.5$/L
5. Liqui Moly - INR 450/L - 6.5$/L
Thank you
