I'm starting to think the lore of the dreaded Nissan/Infiniti CVT woes are a bit exaggerated
Sorry your wrong when it comes to these main components like transmissions or engines. Since there are outfits that rebuild them for the dealers or the factory dealer network in the US. So that means all the parts for them are available. 2 years ago when I redid my daughters CVT in her Nissan car, $5,000. CVT's were available. So dah the part was available.
I also found out the dealers didn't know about the external filter for them, what does that tell you?
What was the "Nissan car"?
You believe rebuilders wonder into a local dealer somewhere and buy parts?
Rebuilders get their parts elsewhere clearly, whether its an engine, transmission, alternator, starter, whatever. The original manufacturer of the part or aftermarket most likely.
Sometimes there is the "herd mentality".........I will just leave that right there.....
Maybe I've read it before and I forget but what is your automotive background is that you seem so confident in your opinions about a lot of these subjects?
I saw enough CVT failures on Nissan's through the independent shops I worked at (in the 5-8 years after they started coming in all their cars, before I left automotive that I would never recommend one to someone if it would be somewhat financially devastating if it was to fail.
People do get lucky and I work with someone who did get 240k so far out of their rogue (all highway driving) and one person had their versa CVT fail at 85k. So 50% failure rate among my coworkers.
So a number of them may be written off or otherwise scrapped before it fails. It doesn't change that it's a high risk of failing at any time.
I know it's not a big deal for people who can afford to keep upgrading every few years like you.
Yes true, but many needed parts are available from the manufacture. So you have to be some how affiliated with them to get said parts.
The normal gasket, seal, frictions are available after market. There is no way they allow us normal nuts, get parts from say Jatco the maker.
I had to order a few ball bearings that were close to the correct size and make them fit. Anyother needed parts or tools you have to make your self.
This is the Internet. Everybody has an opinion. But yea- there is definitely a herd mentality on some issues.
The Rogue is still the third best selling vehicle in its class.
But yea- I don't drink the Kool- Aid.
So this is just your opinion based on nothing. Got it.
My brother and his wife leased a first year murono. Cvt did not last long. In fact back then so many failed that for a while nissan stopped using CVT's in them.
I think this is incorrect. The Murano was CVT only.
The first year, 2002, there were many CVT failures. Nissan HQ had a team of engineers that went into the field and visited each failed vehicle, gathering information on the cause of the failure. Many failures related to software in the control unit, which was improved. By 2003, the failure rate dropped significantly, and everybody was feeling pretty good about the units performance. I think this led to a false sense of security, because that started the ball rolling for mass wholesale conversion of the Nissan fleet to CVT in 2007.
Hit and miss sounds like, but I would wager a large number of them are fine. My brother has had 2 Nissan failures. His 2016 Sentras CVT failed at 30K(oddly early) and his girlfriend just traded her 2017 Rogue with 94K that was slipping badly.
The Versa and Sentra CVT seemed to always be the worst, then progressively better by the next models up, Altima, Rogue, Pathfinder, Maxima, Murano, etc.
I had ruled them out, but I would give them a chance and be obsessive about maintenance. They're sort of fascinating.
The Versa my brother and his wife rented when they came to visit was very nice and I got to drive it for some distance.
You could tell it was always working though, and the sounds and response were a lot like the Iron Duke/3 speed auto in my 86 Olds Calais. It didn't put me off. It was just... curious.
I don't understand though; if they're simpler and cheaper to build for the manufacturer, why are they so expensive to replace? And why are there not booming cottage businesses popping up rebuilding/remanufacturing replacements for far less money?
So yeah, I would own one. In a Nissan, Mitsubishi, Toyota. Never one developed by GM like in the Trailblazer. Nor Ford nor CF Motors [Stellantis].
Sounds like a burgeoning business idea to remanufacture CVTs. My older son is involved with his Baja race team at the university of Calgary. They build their own CVT for their race vehicles. They machine all the parts, but buy the belt, I think. They have almost no budget. Jatco should be able to make one that lasts. Honda/Toyota obviously did.
Years ago(2014?) I rented a Rogue in California and it was the worst, rubber band effect CVT drive ever. Absolutely terrible.
A few months back we rented the Quashqai(sp?) equivalent in Costa Rica and it was a decent drive so there have been improvements. I still have trouble considering a CVT in a new purchase though.
My wife's friend has a 2012 Nissan Altima that just threw a P0868; 156k miles, unknown maintenance history. Intermittent CEL, currently off.
Also shows a P1801 Variable Intake Solenoid Valve 2 circuit issue.
I'm just reading a work order from a local repair shop. I'm thinking of staying away from this one. Although I'm curious.
