Do you know what's in MMO?quote:
Originally posted by Big O Dave:
[QB]
Nothin's more foolish than putting an unknown into your tank!
/QB]
[QB]
/QB]
I will do it again when the thing stops starting with just a bump of the key for the first start of the day ..maybe sooner if I get bored. The stuff obviously leaves no residuals ..even in such high concentrationsquote:
quote:Originally posted by Gary Allan:
Man ..that's a good dose!! Doing that level of add had my 3.0 doing the "light fog" all the time.
Now that your heads are fixed, you ought to try the same dosage again to see what reading you get this time on the ol' fog-o-meter...for purely scientific reasons, of course. [Wink]
[Off Topic!] Speaking of those repairs, have you noticed any differences in power and fuel economy?
This baby is not using any oil. After the MMO the knock was not as bad (or I got better fuel), and mainly showed up under high rpm and high load combined. I should check the timing but the deposits definitely are there and the tailpipe is very sooty black.quote:
If you're knocking is constant under load ..I would tend to think deposits, assuming that the ignition is otherwise tuned correctly. If however your knocking is cyclical with coasting and loading more then just everytime you push the gas from cruising, then I would expect oil dripping into the cylinder and preigniting the fuel charge. This can also occur with heavier blow by vapors.
