It was nice before mainstream GDI came along. Most people here in the south were running 5W-30 or some even 10W-30 in motors that were calling for 5W-20 back then. I ran 15W-40 in a 1997 Mitsubishi Galant (high mileage - second hand) and 5W-30 in a Mazda 6, also ran 5W-20 in a 3.8L KIA motor (a Sorento), and it was fine. But all of them were low compression port-injected gasoline engines.
That won't be too difficult now, will it? How about they require these oils to pass the timing chain test in 1.5 and 1.6 liter turbo engines that have a timing chain. They also have the pass the test while running on regular 86 octane gas. They should also test for LSPI the same way using those same engines. IIRC at least Hyundai, Honda and GM can provide some of those engines. VW cut corners with their crappy 1.4TSI and switched to a timing chain. God, that engine is cheaply made - it doesn't even have a real intercooler and the valve cover holds the camshafts in place.
