Originally Posted By: XCELERATIONRULES
GM's "intake fiasco" is rivaled only by Ford's ignition switch and cruise control switch fiasco.
The number of cruise control pressure switches that have ACTUALLY caused a problem VS the number of GM engines lost to the intake gaskets leaking coolant into the crankcase and cooking the engine? Yeah, I'll take that bet.
I KNOW of three GM 3.8's right off the top of my head that have failed due to the intake gasket situation.
I know of ZERO Ford vehicles personally that have had ANYTHING arise from the cruise control pressure switch.
Lets take this one step further:
Fix to issue with cruise pressure switch: A fuseable link in the power wire to the switch, or a relay to turn the switch off when the key is off. $.50 for a fuseable link, relay is what, a couple bucks? 20 minutes or so to install the fuseable link, maybe an hour to setup the relay.
Problem solved. Permanently.
GM's intake issue: disassemble top-half of the engine to remove intake manifold. Pull off all intake plumbing. Clean and prep gasket surfaces on both the intake manifold and the cylinder heads. Fit with new gaskets.
You then have to be vigilant because the problem can, and often DOES come back, and then you get to do it AGAIN!
Yes, those two issues sound genuinely comparable, I'm quite glad you brought that up.
No need to get testy, I was just having a bit of fun, notice the smiley at the end of my sentence? I really only mentioned it because you are always touting the virtues of Ford, when my experience with Ford has been completely the opposite.
I could go on about how my in-laws drive only Ford products and since 1994(when I met them) have had major issues with every one except a focus that(is strangely enough) a business vehicle, and an 03 Mustang GT (that only see's about 5k miles a year).
I could also tell you about my wifes (then girlfriends) 91 Cougar that had the recalled ignition switch repaired and then promptly caught fire, but I try not to bash Ford too much....
Nothing makes my morning drive like seeing a ford burning on the side of the road.
Delightful!
Nothing I like watching more than a Toyota on the side of the road because the entire engine was plugged solid with sludge!
Or one of their trucks with a flat, and then the frame broke in half when the guy stuck a jack underneath it to put on the spare.
DELIGHTFUL.
And as a true American, and patriot, nothing makes me happier then to see GM & Chrysler eat [censored] because they are traitors to this country. It is very UN-American to make craaap.
As for those workers that work for them and for their suppliers, the Japanese and Korean makes that have factories in the USA might be able to absorb many of them.
