I think it's really high in moly from VOAs I've seen
What molybdenum compound?I think it's really high in moly from VOAs I've seen
Not sure, I found the thread where I saw the high moly content in but it is Idemitsu high mileage so maybe that's why moly is so highWhat molybdenum compound?
M1 AFE? Their ILSAC product can go into the big jumble box with every other majors' offerings.Since you quoted the post twice, does that mean you agree 200%?
Idemitsu engine oil seems good. But not at a higher cost than Mobil 1, or at 85% of the cost of HPL.
Viscosity out of spec is not a concern??Pardonnez moi!!
Pennzoil Ultra Platinum is what went in after the Idemitsu, I’ll send for an analysis of that when due for a change mid summer. I’m well aware of the issues with this engine family so I’m trying to find a good oil and the right change interval to squeeze as much life out of it as I can.Ezrash
Everything's nice except Flashpoint, Shear / Fuel.
I have the same engine. I just changed the oil and used three quarts 5w40 and two quarts 5w30.
I’m definitely not an expert on oils but I believe I read somewhere in these forums that Idemitsu 5w30 was barely in the 30 “category” and almost a 5w20… (if this explains the lower #…or I could be totally wrong) 20 is what this engine calls for with 30 being an acceptable alternative per the manual. Does this make sense?Viscosity out of spec is not a concern??Pardonnez moi!!
PUP is not going to improve the 3 Negatives I mentioned above. The 2.4 and 2.0 from Hyunkia need a blend that keeps the travel viscosity as high as possible - later in the OCI when shearing is gaining traction. These 'very sensitive' engines last longer this way, along with shortening the OCI to 3k.Pennzoil Ultra Platinum is what went in after the Idemitsu, I’ll send for an analysis of that when due for a change mid summer. I’m well aware of the issues with this engine family so I’m trying to find a good oil and the right change interval to squeeze as much life out of it as I can.
My eyes hurt.. I can’t see paying that price.Anyone use Idemitsu synthetic oil? The price is higher than oils sold locally and curious if it’s worth the $39 price….Thanks
The low viscosity number can be explained by fuel dilution which is very likely higher than Blackstone’s estimate.I’m definitely not an expert on oils but I believe I read somewhere in these forums that Idemitsu 5w30 was barely in the 30 “category” and almost a 5w20… (if this explains the lower #…or I could be totally wrong) 20 is what this engine calls for with 30 being an acceptable alternative per the manual. Does this make sense?
I'm paying $15.90 per quart for HPL, shipped to my door (that's with 15% off).My eyes hurt.. I can’t see paying that price.![]()
but why?I'm paying $15.90 per quart for HPL, shipped to my door (that's with 15% off).
That's approx $79 per five quart jug. My bottom line is $191.08 for 12 quarts of two different labels.
So there’s a couple things and they’re not directly about you in any way. The 7.8xcSt result is already in the lower half of 20 grade viscosity window. What was really concerning was that Blackstone says “everything’s great!” When that’s clearly not the case with the oil.I’m definitely not an expert on oils but I believe I read somewhere in these forums that Idemitsu 5w30 was barely in the 30 “category” and almost a 5w20… (if this explains the lower #…or I could be totally wrong) 20 is what this engine calls for with 30 being an acceptable alternative per the manual. Does this make sense?
