I think the solution is a trailer with a water tote until the pros show up...
Ha! You do know that California won't allow older non emissions compliant trucks in the state? Most well trucks are old jalopies! We are over 200 miles from the nearest border state. Imagine driving one of those junkers 200+ miles 1 way to a job
Do you require aftertreatment on oil fired furnaces? Or are they outright banned?Ha! You do know that California won't allow older non emissions compliant trucks in the state? Most well trucks are old jalopies! We are over 200 miles from the nearest border state. Imagine driving one of those junkers 200+ miles 1 way to a job
My cable and wire are tied to the drop pipe every so many feet. Guessing this is a regional code. Don't want 220 or 3pThe cable that was lowering this pump is probably not as far down as you might think. ...
So first you need to know how far. It might be only 50 or 100 feet? ...
Was probably trying to save a few bucks and replace it himself.How did you drop it? What were you doing? No way could you pull that pump and pipe by hand.
A well guy told me they have ways of getting out a dropped pump. Even if you could hook it yourself you cannot pull the pump out without a machine?
Some things that you do infrequently and where mistakes can be costly are best left to the pros.
chafing against the casing if its iron.
I say this as I watch the diesel smoke out my chimney.
Wasn't me! I was just asked about giving them an idea to get it out.How did you drop it? What were you doing? No way could you pull that pump and pipe by hand.
Probably heard you have a mine shaft on your property and figured, what the heck, who would know better then Chris?A neighbor asked me for an idea. Seems that he dropped 400ft of 1.5in pipe with a pump on the end down his well.
Well is 650ft deep so the top piece of pipe is 250 ft below the surface.
I'm thinking of some sort of hook to hook onto the wires somehow.
???. It's 20 ft sections that are screwed togetherThere is more to the story than we know. The water pipe comes off a reel and should be continuous.
Does that stink real bad?Do you require aftertreatment on oil fired furnaces? Or are they outright banned?
I have lived with a well 48 years and always had 20 ft sections. Never seen a roll of it in any well around here.So he didn’t use flexible type pipe?
Man, I would stay away from this mess.
I guess the cable pulls from the bottom too? Must be around a ton of stuff all jammed up down there after 250' fall.... I assume the pros must lower a camera down there to see what to send down to down and what there is to grab. 100's of feet of cable must jam up if you try to pull from the pipe?It had a cable but that went with it lol
