Hyundai sonata 2.4l burning oil
ATL
Should i adjust the weight of oil in the sonata, its been burning 2 quarts in between ocis. I was think about using Mobil 1 10w30 HM with Lucas high mileage additive. guys i need some help on this one i appreciate the feedback. The vehicle has 129,xxx miles on it.
Much appreciated Grambo
I don't want to be an alarmist, but - high oil consumption is a sign of the Hyundai engine failure issue.
My Sonata (signature) burns up to 1 qrt per severe service (3,750 miles) OCI using synthetic D1 / Gen 2 rated 5W30 (i.e. bumped up a grade from oil cap stamp 5W20 ;10W30 and 5W30 also allowed for the 2.4L GDI by Hyundai / Kia) . From what I read it's just an "undocumented feature" that Hyundai / Kia offer buyers of the 2.4L GDI engine ... *If I were you I would visit a Hyundai dealer and start the documentation process towards a new engine .
How about running some slow cleaners with regular oil? like 1 quart MMO or TCW3 added to the rest of 3-4 quarts of regular oil?
Since they are a 0w20-0W10, I would monitor oil consumption at every gas fill-up.
Also there is , drop current oil and filter, add cheap oil filter, add oil cleaner + cheap oil, run at IDLE (DO NOT DRIVE!) for 20 minutes, drop filter and oil and use a good filter and an oil with cleaning properties.
extreme approach: drop current oil, fill to the brim with kerosene. DO NOT DRIVE!!! leave over a weekend, drop kerosene and old filter, leave for 2 hours to make sure everything drained. Add cheap oil and filter, run at idle for 20-30 minutes. drop cheap oil and filter. use good filter and an oil with good cleaning properties.
Unless mechanical problems are the cause, you should be goo to go.
My Kia hasn't burned a drop within 6k miles OCI
Smoke from turbo bearing or ???
I would get that ACEA 5w40 out of there before you kill the cat and TF lambda sensor!
Wonder if rings are varnished. The VW dealer put in an oil that seem different and worse that the factory oil in my turbo VW and the engine now vibrates due to likely poor cylinder balance - which can be typically due to varnished Hot stuck rings.
My 2010 Hyundai Elantra 2.0 burns no oil between oil changes and I do 15,000 mile oil change interval. The oil is Castrol EDGE Extended Performance. Oil filter is the Wix 51334.
I think the non-turbo Hyundai non-GDI engines are a lot more reliable.
FWIW - 2.4 is not a turbo engine
a 5 or 10 W-30 is ok per your owners manual + higher consumption of watery 20W's is common. girlfriends 13 malbu 2.5 drank spec 20 but 10-30 was much better but by 62 thou a qt on a thou + it was GONE!!!
What's the failure mode? (my SIL has one of these so I'm interested in what to look for)
