This is an older version of the bulletin. Not 100% sure if they continued it or not, hence my earlier post.
Service Procedure:
1. Follow appropriate published service information for the routine maintenance inspection items
according to the normal maintenance service interval.
Information is available through
www.hyundaitechinfo.com from the online Owner’s
Manuals and the Quick Reference Guides
Maintenance items beyond the standard engine oil and filter service would be subject to
customer pay.
2. Complete Service Campaign 953 (ENGINE MONITORING LOGIC PRODUCT IMPROVEMENT).
Refer to all contents of TSB 19-01-002H-1 (or the most updated TSB for 953).
Perform the Service Procedure for updating the ECM and Cluster.
Follow Warranty Information to submit Campaign Claim for Service Campaign 953.
3. Replace the engine oil and filter.
Replace the engine oil filter with a new genuine Hyundai engine oil filter.
Be sure to replace the oil plug gasket with a new one when reinstalling the drain plug.
Use Quaker State 5w30 Engine Oil (whenever possible) during the refill.
Refer to TSB 10-EM-001 for guidelines regarding optimum engine oil fill level.
4. Perform the required step below for all 2013-14MY Santa Fe Sport 2.0T/2.4L vehicles.
Enable and set the Service Interval Reminder Feature using the steering wheel buttons.
