I'm hoping we have a few resident heating experts that may be able to help me with diagnosing a recent change in the behavior of my zone heating system.
For the last five years we've owned the house, it's been very good at holding setpoints in each of the zones. But for the last couple weeks, our main floor zone has been holding about 2 degrees higher than the set point. The thermostat knows it, and I've confirmed the thermostat is reading accurately with my IR thermometer. I'm trying to figure where the extra heat is coming from. My second floor zone is fine.
We have an LP furnace, which is set up with two zones. The main floor and second floor. The main floor also includes registers in the basement, which the prior owner added later. So we are looking at maybe 1,000 sqft on the second floor zone and 2,600 on the first/basement zone. Based on what I've read, this is probably a bit unbalanced for a zone system. I do have a bypass damper, which runs open when only the second floor is going.
I plan on troubleshooting this tonight, but I'm sitting at work thinking about what I need to do. At this point, about all I can think of is that maybe my first floor zone damper is stuck partially open? That would mean I'd be getting heat in the first zone when the second zone is running, but the first should not be.
Are there any other failure points I should troubleshoot? It seems like the thermostat is OK, it's saying it's too warm and not calling for heat. But I'm getting it anyway.
