My central heating unit has developed an annoying problem. The blower door pressure switch will work sometimes and other times I have to jiggle the blower door to get the unit to fire up. I have replaced the pressure switch within the last month and had no problems for a couple of weeks, but then the same problem occurred. The unit is inside a door in my garage. It seems like the colder it is outside the more it doesn't work right.
I'm posting here to see if anyone else has had this problem and discovered a fix..... before I'm forced to call a HVAC repairman.
Thanks in advance.
Thanks in advance.
